I was reading the tech article by one of the guys on here, and it showed how he used 1/4 inch polyeurethane foam on most of everything...
Where can i order this at, and how much should i get. ( i have a wagon ) also how much should i expect it to cost me... Thanks in advance.
please...
i think it was AudioSS that had the floor and other parts wrapped in it.. Where can i get some. thanks
J
I get mine from Three Rivers Supply in PA but you need an account through them. Any auto upholstery supplier (jobber) will have this stuff. It comes 54" wide and is only about $5 per lineal yard. Let me know if you need any more help
Be careful with open cell foam. It can lead to corrosion problems down the road. It has a way of holding/trapping moisture against steel.
Peter
