I've been having this wonder for some years and want to get to the bottom of it. If I remember correctly, when I bought this car a piece of hose was falling apart on the Evap Solonoid line that comes along the fuel rail, around the valve cover on the passenger side. This hard line stoped at that same spot repair I did years ago about a little out the bottom edge of the valve cover. I put a new piece of hose there but this has ALWAYS seemed funky to me as it seems to never sit correctly. This repair (about 4 inches) goes onto the same type of hard plastic line that is a 45 degree piece of hard tube with one end having a hose bead. Maybe I melted it and can't remember. Anyway, I suppose that bead is for another hose to splice to the steel line at at frame. I don't know how long the stock one was.. The other end of this beaded 45 looks like it's cracked off. I'm just not sure what the original part legnths, shapes,, bends looked like and would like to know. Can someone tell me how long the sections of the the plastic tube is from the last bend at the top corner of the valve cover to the end of its factory run and how it's shaped? Picture of one? How it's shaped? Lengths? Because I'm not sure what this was from the factory and would like to repair it as it's right In front of me. Does this part get melted frequently? Is this what happened to mine? Need some ideas on how people have fixed this because as I remember this may be a tight type of run for that line and help would be appreciated so I can get the job done nice and correct. And yes, I learned the hard way. Pep boys called the wire loom heat resistant. My alternator shows it wasn't. I'm going to be putting some grey stripe on that.
