Has anybody have had their rear exhaust manifold bolts snap? Found two broken/ missing on my motor today.
The fancy option: https://www.summitracing.com/parts/ARP-400-1210Now to find part numbers and parts. Should be fun try to find the one that has threaded stud on the top.
Unless Caddylack corrects me he's referencing bolt lengths when installing most aftermarket headers, as those do not use the spacer collars at any locations. For your oem manifolds you simply need GR.8 1-1/2" at all places except the centerboard 2 holes each bank with no collars - for those you'll need 1". And for the alternator bracket stud you refer to, I have never heard anyone in 25 years report that one as snapping. Indeed, I personally have yet to recall any post of snapped bolts at any locations other than the rearmost 2 holes of either bank. My 'guess is those are just that extra teeny bit hotter locations against the firewall to nudge those bolts to failure.Now to find part numbers and parts. Should be fun try to find the one that has threaded stud on the top.
Well, it's true that I was referring to my aftermarket headers, but...Unless Caddylack corrects me he's referencing bolt lengths when installing most aftermarket headers, as those do not use the spacer collars at any locations. For your oem manifolds you simply need GR.8 1-1/2" at all places except the centerboard 2 holes each bank with no collars - for those you'll need 1".
Yes I saw the pictures I hope it doesn’t happen to me I hope there’s something left to grab onto Time will tell. My luck it’ll be flush. But I do have a mig welder.Unless Caddylack corrects me he's referencing bolt lengths when installing most aftermarket headers, as those do not use the spacer collars at any locations. For your oem manifolds you simply need GR.8 1-1/2" at all places except the centerboard 2 holes each bank with no collars - for those you'll need 1". And for the alternator bracket stud you refer to, I have never heard anyone in 25 years report that one as snapping. Indeed, I personally have yet to recall any post of snapped bolts at any locations other than the rearmost 2 holes of either bank. My 'guess is those are just that extra teeny bit hotter locations against the firewall to nudge those bolts to failure.
For extracting snapped bolts there's the slik n short 1-step weld-out method shakenfake used. Just that Step 1 is: 'Get a welder'.And I've had luck with a lt. hand bit and an extractor. On one occasion the stud backed out while just using the drill. In ANY case it's important to loosen the broke part with repeated doses of heat, beating on it with nailset and PB Blaster before attempting any extractor. And on the rearmost bolt you have an extra option, and if you read that thread I'd appreciate knowing whether you can view all the pics:
Broken Exhaust Manifold Bolt
[EDIT] - 2/5/23 Most all the pics were hosted using Photobucket (which has turned into a pay site) and my attempt to replace them all using Imgur is not successful. You may (or hopefully may not) require using the 'Photobucket Embedded Fix' to view them. Here's the one for my browser, though...www.impalassforum.com
From the forum a list including what could be needed if you R&RNow to find part numbers and parts.
ORI've never seen a stud break, and never replaced a stud on my cars. I do, however, loosen and retourque the studs when I replace the bolts.
ORIf you need the threaded studs, that is actually a common and universal part. Farm & Fleet has bins full of exhaust studs in the nuts & bolts section.
Some people may misinterpret this statement.When buying a set of bolts, you would obviously rather be slightly too long than slightly too short, since too short won't work at all. With stock manifolds, you might consider 1" bolts instead of the 3/4" I recommended for headers.
The reason is that you are making extra work for yourself, and it's not exactly an art project.OR
Get threaded rod in your choice of grade and make your own.
(If there is a reason not to do this post a correction)
Right. What I meant was that a longer bolt can sometimes still be used with a spacer or washer. A bolt that is too short to thread will not work at all.Some people may misinterpret this statement.
In 1994 there was a TSB 44-67-03 the block was tapped too short and the bolts would bottom out. If longer bolts are used the user should make sure there is a allowance (spacers or cut the bolt) so that the bolt used does not bottom out.
I hope the manifolds aren’t cracked due to the two missing bolts. Where do they usually crack?The reason is that you are making extra work for yourself, and it's not exactly an art project.
Is there a reason you would walk past the bin that says "exhaust studs" and buy anything else?
Thank you for the reference pictures and part numbers.I hope the manifolds aren’t cracked due to the two missing bolts. Where do they usually crack?
You are probably fine.I hope the manifolds aren’t cracked due to the two missing bolts. Where do they usually crack?
The exhaust manifolds almost never crack.I hope the manifolds aren’t cracked due to the two missing bolts. Where do they usually crack?
