1 - 20 of 20 Posts
is there a difference between the f body and the b body lt1 pulley?
my motor is from a f body and the crank pulley doesn't seem to line up with the others.
any help
well here is my problem. they dude that had the car before put a f body motor in. so the crank pulley sets back about 1/4 of an inch. i was wondering how to correct that.
To add , you need the impala hub for the year the "F" body engine is from. That is to say if the engine is from a 96 or 97 "F". You need a 96 Impala hub even if your car is a 94-95. If the "F" engine is 95 or older, you need a 94-95 impala hub
Anyone know where to get the keyed hubs for the 94-5 Impala (4.09") BESIDES thunder racing (they are backordered). Thanks.
Discussion Starter · #15 ·
And how would I tell what year my motor is?
If your Fbody engine has an unvented opti, its a 94 or older.
If it has a vented opti, it's a 95 or later, and if it has a crank position sensor in addition to a vented opti, it a 96-97.
I have converted my two '94 F-body engine optis to be vented.
They still have the spline drive but without a close inspection they would appear to be the vented type. I know some have also installed "conversion" kits. I know the possibility is small but ...
The F-body banancer is different in that it doesn't have the three tapped holes. I don't know if that is the only difference.
F-body balancer: http://shbox.com/1/pull_pulley.jpg
I think you will find that once the 94 "B" damper showed up the the early "F" damper was phased out at some point. I have worked on original 96 "F" cars with the additional holes.
Looks like
# 12551138 is listed now for 93-97 "F" and 94-96 "B"+"D"
Of coarse the LT4 "F" is different but they are so rare listings ignore them.
1 - 20 of 20 Posts
