I hear alot of people talking about the 3.5 F Body MAF. I was just wondering what are the pros and cons of this Mod. Will any other mods need to be done to accommodate this?
.....3.5 F Body MAF.....what are the pros and cons of this Mod.....
Pros = Larger diameter makes for more airflow = more power potential
Cons = different calibration tables which requires a PCM tune.
That is all.
KW
.....your engine probably doesn't flow enough [air] to need the F-body MAF sensor......
That's really not a con, when you look at it.
A 3.5" with a tune ain't gonna help performance (beyond whatever boost the tune gives you).....but it ain't gonna hurt performance or the engine.
You waste the $50 or so that it took to buy the MAF.....but so what?
KW
I've had this arguement before, even with all the bolt-ons, you won't need the F-body MAF. IMHO, the F-body MAF won't be needed till you start adding better cam and heads ALONG with the bolt-ons.
My 96 had all the bolt-on and when I install the F-body MAF and 52MM TB, it lost power! The car had to be tuned to retrieve the power that was lost.
.......when I install the F-body MAF and 52MM TB, it lost power! The car had to be tuned to retrieve the power that was lost.
You cannot do a F-body MAF or a 52mm TB without a tune.
Tune is needed to optimized the set-up (the catalyst for your power gains) and in the case of the 52mm TB, the tune is needed to prevent damage to your transmission ;) !
KW
fwiw, I have the Clear Image 3.5" cold air intake, and I had some odd-looking diameter changes hooking that up to the factory 3" MAF.
I used a F-body MAF and program, primarily so the cold air intake would hook up nicer.
