My driver side door panel has cracks and I have been searching around for a new replacement but can't seem to find any. Does anyone sell new replacements? (95 impala)
Short answer..No or at least none I've seen. Have seen some aftermarket fiberglass ones though that would need some work.
Your best only option may be used panels or try to repair yours. There is info here on how to take these apart and maybe you could use good parts from other panels? At least that's my plan at some point with spare panels I have from other cars. I always cringe every time I need to remove the front panels cause they are so flimsy and already have some issues.
someone needs to step up and make them!
I have posted a number of times on repairing the door panels with MEK. I have recently started using fiberglass screen to reinforce the repaired cracks, then coating them with a scrap plastic and MEK paste.
