4100 lbs is with all the nitrous stuff but no AC.You may want to get it on a scale as I bet it's more than 4200 if you now have two turbos and nitrous tank and all the other stuff. Unless you took weight out of the wheels or the 4100 was when it still had AC? If you changed nothing but added the other stuff it's weighs more than 4200.
I wish the HP calculators had an addition for superchargers to account for blower drag. Turbos don't need that but superchargers have to account for the additional HP loss in the engine. You can see that by fuel load to the motor and then know what the actual HP level is in the engine.
Fantastic.
Need to name your car the Freight Train..
Hauling down that weight requires good brakes.
More sorting ..mid nines!
You have 20 more MPH to go on those brakes. Mine are stock on the rear and the fronts are just a better rotor with Hawk cold pads. So far it's stopping 4500 at 156 MPH with no issues. The setup is fine driving around and the only thing you have to watch is you don't want to drag the cold pads. They let you know if you are as they squeal. Talk to Bill Harper on brakes as I think he knows the most across the board.4100 lbs is with all the nitrous stuff but no AC.
I'm guessing each turbo weight about 30 lbs, + the piping and intercooler and water/meth injection pump should add up to 100 lbs at least.
I have to admit that I'm pleasantly surprised of the performance of the stock brakes. I have rear discs from a 9C1 and stock B4U front brakes. I've installed premium rotors and pads but nothing too fancy. I've also changed both "bolts" in the combi valve.
It brakes really well considering the weight and speed but it creates A LOT of brake dust after a pass! cwm4
I've noticed of late that the ET Records Page is not up. Does anyone know what's going on with it? Very valuable page IMO.
And I thought it was just me.....Yea but have any of you tried clicking the "Details" button? Mine comes up blank on every single car on the list. I could give a damn what people run if I can't see the mods and other important details listed that info was golden....Hasn't worked in over a month for me.
Got it, makes sense. I was just curious.Karl had intentionally left multiple entries for the same car in the same class when he thought the setup had changed enough to merit attention for how the change in setup affected performance.
But over the past few years, the "duplicate" entries have been largely just a result of lack of time for Karl and Cheston to perform maintenance/cleanup. I know Mike Harris and I have duplicate entries where there's really no significant setup changes, just tweaking and refining.
I've tried to avoid the duplication when I've submitted entries by emailing Cheston or Karl something to the effect of "10.xx timeslip to replace 10.yy current entry in the list, but I can see how that loop doesn't always get closed if they're in a hurry.
A full Stocker cam can sing high rpms.Crazy Dan,
Let's see the duration numbers on those "Pure Stock" cams
They're capable of spinning a lot higher and making quite a bit more power than stock duration cams. Stock lift means ramps are gentler, thus managing to work well with the light springs.
You're right; you should be in Class 4. Email Cheston and Karl to fix that for you.
