Fel-Pro engine gasket set 260-1650.Has anybody use this gasket set for a reseal? What did you think of the quality? Has anyone used anything better? 1996 Buick Roadmaster
You were right about the gel pro gaskets
I was only able to find one available on eBayI used them in my alloy head LT1 with no issue.
The factory gaskets seem to be available from Ebay sellers
Going higher on the thickness would mean less compression. The thing I don’t know is if I go with a thinner gasket would there be any clearance issues? Going from .029 to .026.And why do we care ? .010 difference in these cars is roughly .25 points difference , so imagine putting the .050 F-Y body gasket in place of the .029 B body , you'd lose 1/2 a point!!
No worries, this has been done multiple times since the early 2000s by numerous bygone ISSF elders with no concerns or issues raised.... don’t know is if I go with a thinner gasket would there be any clearance issues? Going from .029 to .026.
Obviously I am not an engine builder I was hoping to get all the right parts together so when I go to do the job which is a reseal on a stock motor with 80,000 miles. Just looking to get all the parts in the party starts I don’t have to go running around in search of. Any other suggestions on that mileage that would be good to address would be appreciated. From what I understand the valve springs are too good. Any recommendations in that department or anything else would be greatly appreciated thank you all.Going higher on the thickness would mean less compression. The thing I don’t know is if I go with a thinner gasket would there be any clearance issues? Going from .029 to .026.
Works.
[/QUOTE
From what I understand the stock valve springs or not too good. Have you changed Valve springs and if so which ones do you recommend?
