1 I have inflatable restrant light on how can I get it off?
2 I am trying to find the center part of my steering wheel
3 If I were to go to an aftermarket steering wheel what would I have to do to disable the SIR system or anything that will trigger any lights on my dash
4 My steering is very lose I have to much play in my steering wheel
1 Install the airbag.
2 Junk yard...what color is it?
3 Put a 2 ohm 10 watt resistor across the yellow connector under the dash. I found a 2 pack of 4 ohm 10 watt resistors at Radio Shack, and used them in parallel. It will act as if the airbag is still there, and flash (test) the airbag light.
4 Could be the steering gearbox, the intermediate shaft, or worn components. Turn the steering wheel and watch the shaft...if the input shaft of the gearbox turns with the wheel it is not the shaft...if the gearbox moves the pitman arm in conjunction with the input shaft the gearbox it is not the gearbox...if the gearbox input shaft moves substantially without moving the pitman arm, the gearbox needs adjustment/replacement...if the pitman arm moves without moving the linkage, it is the center link... If the center link moves without the wheels moving, it is the some/all of the tierod ends.
