hows the out of the box fitment for the fiberglass bumpers?
any probs, id like to get the smoothey front without the fog light openings but the bigger opening in the bumper for my front mount, and seems like you can only get that combo in fiber glass
thanks
I picked up a FG front from someone on the forum. It was pretty straight forward. I measured the hole spacing on the OEM, and transfered them to the FG part. Pretty much bolted up. The flanges at the wheelhouse extensions were a little narrow, and I ended up running the screws closer to the edge. Use the reinforcements from the OEM bumper to clamp the FG one in place.
The wagon rear roll pan from Bell Tech was a pretty easy install too. I just had to get the holes drilled correctly. It took me 3 tries to get it right. It just made the hole shapes a little wierd.
Make sure the panels are sun baked to allow for any outgassing before painting. Wear gloves and long sleeves to keep the FG off of you so you do not get the itch.
