I saw your parts request, and commented on it. The small hose is difficult to pull, but is available new. It is about 10 inches long, and you must drop the tank to change it. The larger hose is easier to pull, but they are both getting old, and the ones on the donor cars may be just as bad as the ones you have now. A section of the larger hose may also be available at O'reillys, so I would try them first. You will probably buy more than you need for one car.
Try changing them on a hearse. Total special part that is alost impossible to remove. I made one with some rubber hose plus exhaust pipe in the middle.
