·Yes, it's been what 4 years since the original group purchase when I bought my uppers and lowers. And I just this past weekend installed them.
I have to say. If anyone is going to replace their uppers. Don't screw around with a gear puller or bushing tool. Myself and a friend (Certified Aircraft Mechanic/Engineer) did for over 9 hours. Just for one side. With 135,000 miles they didn't want to move more than a half-inch.
Tap out the inner metal sleeve, then use a saw-zaw and cut from the center hole straight through the rubber and the outer sleeve. Make sure you keep the blade parallel to the sleeve and you won't have to worry about cutting too far.
When you slice through the outer sleeve (much more quickly than I expected), the whole bushing will POP and jump out of the flange along with your saw-zaw.
I really wish I had done that first but I had to buy a saw-zaw and really didn't want to.
I got the extended kit. I also had to install the lowers first. The uppers just wouldn't align otherwise. I put the HerbAdam's bar on (also sitting in my garage for 4-5 years) but kept the stock front.
I get a clank from the back when hitting a hard bump, and I know everything is torqued to spec. Not sure what that is.
In a hundred miles or so I'll recheck the torques.
FWIW: I did have to release the brake line splitter from the diff-housing, the ABS sensor line from the Stock driver's side Upper control arm and also be very careful about the driver's side emergency brake cable (completely tight with the axle lowered past shock length).
Now I need to make a Z bracket for the brake-splitter and figure out how to mount the ABS line.
