I had done ALL the troubleshooting procedures, fuel psi, fuel filter, checked the new fuel pump wiring, Tested coil/ICM/TPS/IAC, Inspected the front half of the opti, changed the IAT, CTS, MAF, trans TS, plugs and wires, to no avail.
Because i was lazycwm5, when i checked the opti a few nights ago, I did it with the back-half still bolted onto the engine, and just pulled the cap, looked around, and bolted it back up.
It did DIFFERENT than it did before i took it down, but still not right. I finally noticed that even though the car acted differently each time i troubleshooted it, it never really acted any better, and the symtoms seemed to repeat themselves eventualy.cwm3
I pulled the opti off the car last night, and after pulling the rotor so i could actually see what was going on under the rinite (sp?) divider, i saw that oil had once again invaded the opti
I changed the WP DS and opti seal, took some QD electrical cleaner and sprayed the oil out of the 4 OS slots, and followed up with canned air, to help force dry anything left under the metal "shields" that cover the OS slots. I also sprayed the entire opti with the QD, to get any residue out, and gently scrubbed all the oil residue off the OS wheel.
Ive done this several times now, and after noticing the pattern of how the oil ALWAYS comes into the opti, I believe ive found out how to stop it. Im not saying that you should live with a bad opti seal/bearing, just saying how to give the opti a better chance of surviving a situation involving a seal leak if one ever arises.
Under the rotor, the round plate that all the spinning parts are bolted to in the opti, is what the opti shaft is pressed into from the back. Every oiled down opti ive saw has always had the underside of the rotor really wet with oil, and from looking at the tracking the oil leaves on the OS wheel/rotor underside, I determined that the oil was seeping into it around where the plate is pressed onto the outer shaft.
I took a dab of ultra copper and just smeared a lil around where the pressed together pieces meet under the rotor, just enough to fill in the lil valley they create (i took extra care to not use too much, and not get any on the OS wheel). Time will tell if this is really where the bad stuff works its way in, but im pretty sure due to the pattern it leaves on the OS wheel, that its coming from under the rotor, and not from behind the OS wheel.
Ill report if anything happens to the opti, but right now its doing great, it actually cranks on the second "whine" of the starter again like it should, and its super smooth under 2500rpm now. The TCC i suspect was unlocking due to the horrendous power loss that the miss was causing, and the TCC lockup was really exagerating it. I just thought my car was idling around sounding really "MEAN" since the 3000k stall, but now i know better!
