My electrical door locks on the White Elephant (92 OCC, the bane of my existance) would intermittantly lock the doors when I pushed the unlock side of the switch. I found that the remote module has a path from the unlock side to the lock side of the wiring if a relay is shorted internally. I changed the remote module, and now the locks work correctly.
I suspected this as the problem for a while, but just recently had the opportunity to check the wiring diagram in the FSM. Finally I can use the door locks as they were designed. One of these days I will get around to programming the car to my remote. I am going to put both car on the same remote, so that I do not have to carry 2 with me.
