Anyone know what color the power wires (up and down) are on a 95?
Window goes down but won't come back up, trying to eliminate the switch.
Fixed the problem.
Wires are brown and blue in case someone else needs the info in the future.
Oh Thank You Thank You
I was going nuts tryna figure what you were up to. I read your OP as which is the up wire and which is the down. cwm3 Even more confounding as it sure sounded like you were determined to cut the switch out of the circuit altogether, and use ???????? instead?
A classic case of, Let's eat Grandma, and, Let's eat, Grandma. ;)
