1 - 20 of 58 Posts
post your pics of you floor shifter conversions. i want to see if they would turn out good in my impala
Recently swapped in the 96 setup into my 95 caprice. Did it all including the Steering column. Don't have pics to post but then again it looks just like any other 96 Impala. Next to my Bonny seats and Z/28 cluster this has been one of my favorite mods. If you have the time, parts and know-how, I say...Do it, you won't be disappointed.
it looks like a jimmie console & shifter
Mine is not an Impala, but here she is...
Bravda console w/ custom leather boot and dyed handle.
Started out with this:
Removed part of the driver's seat:
One of my all time favorite mods. :)
HTH.
I've been thinking about a custom console and shifter also.
I've always wanted a Lightning Rods Shifter.
Not for my RMS, but maybe in another project:
Yes. They are expensive.
But, oh so cool! :)
Ok I guess that I will bite on this one here is my first console, Bonnie
I never finised that one, I custom molded it to the dash
Here is my new console, not done yet, but it is from a 93 SHO for my T56
QuistBurgundy- were you in Kzoo a couple of days ago, I sware that I saw you.
Stewart clean that damn car already it is looking a bit dirty j/k :)
Mike
Discussion Starter · #15 ·
Im leaning to custom fab a console, using one of these shifters
yea i think that i might have to do what you want to do, my column shifter broke on the inside of the column and now i cant shift, so i might as well go with a floor shifter because i dont want to replace the whole steering column. i wasnt too sure if i wanted a floor shifter but now that my column shifter broke, the logical thing to do and less expensive thing to do would be to install a floor shifter
Putting bonneis and a blazer along with Z28 cluster in my 94 SS
The bracket I welded based on other guys whohave done the same.
The one I did for toomanytoyz
Building a drivers bucket sear for Ron "ICEMAN" for his T-56 roady using a passenger side seat upholstery and modified cushion and frame.
Bonnies and a blazer in me 95 fleetwood.
I moved the t/c button from the glove box to a plate I made to cover the hole in the seat left by the original seat controls.
Discussion Starter · #19 ·
does anybody know if the 1997 z28 auto tranny shifter will fit in a 94 ss console if i take out the cup holders?
It will... you will need the console plate from the Camaro to patch into the console
where the cup holders were, bondo / fiberglass it together & paint it SEM trim black.
You`ll probably need to fab a bracket for the shifter to be raised high enough to work
properly. That`s what I did to my `95 DCM originally, then decided I wanted the
Hurst Pistol Grip Q-stick... I think it turned out OK...
1 - 20 of 58 Posts
