Anyone have good suggestions on front door panel repairs?
Specifically, the mounting points on the panel for the panel to door christmas trees to mount to. The metal clips are off. I have some glue that will hold the metal clips on just fine, but there is at least one plastic location that didn't survive the panel removal.
Also, the door panels on both front doors are broken around the bottom non-hinge side screw. This screw goes right through the panel and keeps it from flapping. The plastic busted out of both sides long before I needed to remove the door panel.
My passenger front slider was busted. Friday I forgot and rolled down the window. I stopped and held it level while I rolled it back up, but now today it appears stuck when I went to fix it. I don't see any obstruction, the front arm is not caught on anything and the back slider appears moveable but the window mechanism won't move. It does click when the switch is depressed, though. Just no go.
Even if I get the slider changed with a roller, I don't think my panel will ever go on the same again.
Any suggestions?
-PJ
Any suggestions?
-PJ
