I have 3/4 inch MDF that I would like to cut to fit some 6 1/2 componets in the front doors, But the plans read that it needs to be 1/2 plywood or particale board.
But would 3/4 MDF pose a problem with anything if i use it?
TIA
H
1/2 is the minimum that I would use, 3/4 should be fine.
i used 3/4 i found i had to cut a little off the template. and had to sand down some areas to allow the door panel to be flat. but can be done. 1/2 would be best.
H
3/4 inch is fine. That's what several folks have used and like Camel said, you'll just need to sand / shave some off the edges. If you need some help, I'm up in the Bear Creek area off 6 & Clay.
