I just finished pricing Moog steering and suspension parts and it looks to be $300 to $400.
If I ordered everything I wanted for the steering suspension and brakes it comes in at $700.
Problem is this is a 93 chasis I'm rebuilding and most if not all these items need replacing.
The Moog prices seem to be compairable to the GM/ACD prices in the Bill Harper "ACDelco suspension parts" thread.
With the body off the frame I want to do everything and not be crawling around under the car later when the body is back on.
What parts and were purchased have others used that are cheap/affordable and satisfied with?????
I'm looking at steering linkage, control arm bushings(front and rear),ball joints, etc.
N
Facts of life--parts (new & used) will only get more expensive over time. An out-of-production vehicle is an opportunity to raise prices, as it costs manufacturers more to produce smaller quantities of replacement parts that are application specific--prices go up to maintain equity in the effort (ie. profit).
Fortunately, many of the front suspension parts used in the B-body are common to a number of vehicles & years, with a fairly sizeable population still on the road, so demand is still there, even though cars/trucks using the parts are mostly out of production. 73-77 A-body, 77-up B-body, 70-81 Camaro, 75-79 Nova, 78-88 G body, S10 pickups, and Astro vans share(d) a number of parts--only Astro remains in production, and running gear/suspension has been revised, so I don't know if it still has any commonality with any out-of-production vehicles. Lower ball joint for Astro was same as Moog K6141 (5/8") as an example.
Moral: take care of your stuff, plan ahead. Remember, no one feels sorry for orphans in the car business.
Check vendor section, for starters:
http://impalassforum.com/noncgi/ultimatebb.php?ubb=get_topic;f=18;t=001124
and there may be others. Have you checked with Dal?
K
That's really not that much money. Plus it's not like you have to replace those parts every 3,000 miles. I would focus on getting good quality brand name parts. You don't want to be trying to save a buck or two when it comes to brakes/suspension parts. If I recall when I last did the front end on my Crown Vic I spent about $350-400 for upper and lower ball joints, bushings, tie rod ends, pitman arm, idler arm, etc. You can shop around a little on price but not much. Usually Advance or AutoZone carry decent suspension parts from Dana and TRW.
Call Dal, AC Delco, can't beat his prices, at least in my book!
Dave
I got that same sticker shock when I rebuilt the 1/2 ton suspension on my suburban when I did my conversion from 3/4 ton. Not to mention I got ripped off on the 1/2 stock 30 year old suspension and payed $400 plus another $300 to rebuild it with new bushings, ball joints, and tie rods......
