·I'm looking into putting Koni's on my SS myself. First I want to ask everyone here if this is something I could do in the garage?
I've looked at the procedure in the FSM and it seems too easy. Raise the vehicle, hold the shock absorber using J 25591, remove the nut, retainer, insulator, bolts/screws, pull the shock out from the bottom. Now, am I missing something here? Not a lot of work to get the shocks off. I guess installation of the new shocks is reverse of removal?
This may be a dumb question, but I want to ask this because I don't want the control arm falling on my face! If I take the shock off the control arm, will the control arm still be supported? I guess I am asking what keeps the control arm connected to everything?
I've heard from a mechanic friend that shocks are a major pain on B-Body's and that one would have to break the top of the shaft of the old shock to get it off. The FSM does not mention this. Can anyone comment on a shock install that they have done, and if I should watch for anything special?
Thank you!
Thank you!
