1 - 15 of 15 Posts
T
Ok, tell me what the heck is up.
I'm serious. When hitting bumps or ruts in the road, I hear what sounds like loose change gingling in a pocket.
Along with that, the car drives like the tires have about 5lbs in them.
I have 136k on the car, with the tierods, centerlink, idler and pitman being replaced at 80k (moog problem solvers).
So, could this be bad balljoints or control arm bushings? I get the noise on both sides.
Along with that, it almost feels like the wheels "whobble" and I get a distinct feel that when cornering the outside wheel wants to turn tighter than the inside wheel.
Any ideas?
A
Betcha a 6-pack that one of the following two things has happened
1. Your front swaybar endlinks are either VERY loose or just downright GONE
2. Your upper A-arms are loose where they attach to the frame, and thus you have loose (or missing) alignment shims
T
I wouldn't be shocked if it's the shims. I've had those fall out about 4 times since I bought the car with 55k. Never had the noise though.
Well, I guess it's time to get all the bushings and such up front replaced, and get my Metco uppers and lowers put on. They've only been sitting in the garage for 3 years or so now.
L
Also sounds like it's time to find a good Wheel Alignment Shop to install correct amount of shims and TIGHTEN the Upper Control Arm Pivot Shaft to Frame bolts to correct torque spec(70 Ft.-lbs.). Loose change noise[as per AutocroSSer], I'm betting Sway Bar End Links.
L
Dude,
recently heard same noise - both front stabilzer links obliterated on my '95 DCM - problem solved and drastic handling improvements. spray with wd40, big help when nuts / bolts do not put up a struggle. GOOD LUCK!
O
wheres the best price online for new sway end links?
J
The cheapest way to solve this front end noise may be Auto Zone $6 pack of front brake caliper rubber bushing.
W
Is this model specific or do they sell a universal bushing?
(or are all the applications the same?)
L
O_loung1, go here www.performancesuspension.com These people are located in Phoenix, AZ Tel.(800)572-3768. You want the Polyurethane Front Sway Bar End Links...I paid $15 for mine. Edit Add: I also changed out Front Sway Bar Insulator Bushings(these are the bushings that hold SB to frame). Using an Adjustable Wrench, measure O.D. of your SB and get the H.D. Bushings(made of Thermal Plastic) by Moog. These install with OEM U-Clamps. Make sure, slits in Bushings face forward, when you install them. Any good Independent Auto Parts Retailer should stock or can order them for you...about $12. BTW, be very carefull, when reinstalling U-Clamp to frame bolts, threads in frame strip easy!!!
i've got this same problem, very good description of the noise it was making. thanks again guys!
O
wow, thanks alot Larry! looks like i ll messure, call, and order.. and thanks for the frame stripping tip!
Same kind of noise for me, but went silent when brake is applied. I am going for brake bushings. Thanks VAM
L
Discussion Starter #13
VAM, When you do Caliper Bushings, also change out Metal Sleeves. Also make sure, when installing Outter Brake Pad, that end tabs are tight on Caliper.
Discussion Starter #14
your brakes are loose, it's the pads, they are loose on the caliper, there is a tabs on the outer brake pad, the tabs have to be turn in were the pads would hold on secure.
J
Discussion Starter #15
WR250Z
Member # 778
posted 09-09-2003 11:19AM
In Auto Zone there is a pack including caliper bushing, guide pin sleeve and pads clip, $6.99 each, part number H5539 (Wagner part # F73674S, Bendix H5539, Raybestos H5584).
Good luck to solve the front end noise problem.
Jesse
1 - 15 of 15 Posts
