I'm putting my front end back together and ran into a snag with the upper control arm bolts. The pieces that came out were way rusty. The shims were also rusted into a big mess. Does anyone have the part # for the upper control arm knurled bolts? What about the shims? Is there a certain amount I need? I didn't keep any of the stuff that came off.
T
1992-96 Bolt, front upper control arm 10262655
At least that is what the micro fish says.
Get the shims from an alignment shop, or better yet leave them out and let the alignment shop put them in. You will need an alignment when you are done. I hope there is a shop close to you, or you have a trailer. Driving any distance without an alignment can F up your tires bug time.
There is no "set" number of shims, it all depends on the car and the parts.
Thanks alot. Yeah, I'm about 10 mins away from an alignment shop. I plan on throwing some POS almost bald tires on for the trip over there.
