1 - 1 of 1 Posts
I had an "OOPS" moment, and cracked the front glass on my wagon. I was checking the cowl for a blocked drain, because I was getting a lot of water in the cabin. The glass in itself is not a killer. Replacement is only $180. The kicker is that the body under the glass is rusty from the center to the passenger side. This may well be the cause of my water problem. The window was effectively only attached across the bottom from the center to the driver side. The area under the window was wet when the window was removed, so the water could very well have wicked up into the passenger compartment. Repairs to the body and properly sealing the window should cure my leak.
I write this for all those who have PS leaks...it could be your front window.
1 - 1 of 1 Posts
