1994 DCM (Dark Cherry Metallic) Chevrolet Caprice Classic
I purchased this 1994 Chevrolet Caprice in early 2003 with 112254 miles. The car is as similar to a real Caprice SS (Export) of the era, minus the rear spoiler. The vehicle is prewired with coaxial and other wiring for police use. Two antennas were once in the vehicle's trunk lid and are plugged with stoppers, however there is no indication it was purchased or used in a police fleet. (see Vehicle History Report)
Around mile 133,000, the engine threw a rod and I had it, and the 4L60E transmission rebuilt. It is now a 383 stroker. Quality parts were used however the engine rear main seal leaks oil and needs fixed. I'm selling the vehicle because I have limited time to work on it. This is a non-smoking vehicle, ashtrays never used. Backseat and passenger seat was rarely sat in. The car in street form ran a low 13 on 93 octane gas. With the included drag radials and a reprogram it should be a 12 second car.
The vehicle features the following options:
Cloth front and Rear Seats
Power Windows
Power Driver Seat
Power Passenger Seat
Power Door Locks
Cruise Control
Dual Air bags
255/50 ZR17 BFGoodrich G-Force T/A tires mounted on Impala SS wheels @ 136,125 miles. Lifetime Warranty is transferable to new owner. (Discount Tire)
Air Conditioning (new compressor installed 2010, needs charged)
Power Steering
Tilt Wheel
Drum Rear Brakes, Disc Front Brakes
Original Floormats
Electro chromatic Rearview Mirror
The Caprice SS features the following visual mods:
Tinted Windows
Caprice SS / Impala SS Wheels
Corvette LT1 Dress Kit
Caprice SS center console decal insert
Original GM Export Headlights (made by Guide Corporation, Anderson, IN)
Painted Body Trim to match vehicle color
Pioneer XM Ready AM/FM/CD/MP3 player 50Wx4 Stereo, w/remote
Z28 Cluster mod with Tachometer wire. The original Digital Dash will be included with the vehicle.
Corvette Magnesium Valve Covers
The Caprice SS features the following performance modifications:
Transgo Shift Kit
4.10 Gears
Stronger Tubular Control Arms
Eibach Lowering Springs (original springs included)
Large 6 Quart Oil Pan
Aluminum Driveshaft
RAISS Air intake Kit
High Stall Torque Converter
ECM Reprogrammed by PCM4Less (done prior to engine rebuild)
Dynomax 2.5" Catback Exhaust
Export Pipes (cat delete)
Clear Image Automotive Tri-Y Headers
Lloyd Elliott LT1 LE2 heads (Ferrea 2.00/1.56 6000 series valves, Comp 26918 bee hive springs, Comp 795 10 degree retainers, Comp 611 10 degree locks)
Comp Pro Mag 1.6 NSA rockers
Comp Hi Tech 7.200" pushrods
Comp Cams Cam Specs: 230/230 .600/600 110 LSA
Rotating Assembly Specifications
SBC # 38360F
Stroke - 3.750"
Bore: 4.030"
Cubic In 383
Rod Length 6.000"
Piston Type: Flat Top
CR 58 cc 11.8
CR 64 cc 11.1
CR 76 cc 10.1
Piston: SRP
Std/File: STD
Piston Material: Forged
New Fuel Pump and Fuel pump sending unit - March 2011
New PCV Valve and Map Sensor - March 2012
Known Vehicle Issues
Rear Main Seal Oil Leak
Left turn signal needs fixed (could be a bulb)
New bulb needed in center console
Rear windows need new rollers (common issue with all Caprice / Impala SS)
Typical road wear, a couple of door dings. Some touch up work wouldn't hurt. The hood has scratches, not easily visible until you are up close.
Headers were powder-coated several years ago and have since rusted - need removed and re-coated or chromed for a show look. No Spare Tire Included
Parts Included with the Vehicle
x2 Micky Thompson Drag Radials
x1 Herb Adams Front Sway Bar
Rear Disc Brake Conversion Kit (~600$ worth of new, boxed parts)
Original Caprice LT1 Iron Heads
Original Rear Sway Bar
Original Caprice Digital Dash
Original Springs
Vehicle is listed on Ebay here.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120893099906
Any questions, feel free to post or pm me here.
I must say , id love to add her to the Fleet
I always had a soft spot for the 94's
I thought the way "Forums" work was to give the B Body Community first shot and a discount ! hint hint
Then Fleabay !
btw you left out your selling price ?
Thanks for your interest. Of course, I'd rather see this go to an enthusiast before Ebay.
I really did not know what its worth with the rear main leak.
That said there is a lot of money in parts alone that it would be a real nice parts car if someone didn't want to fuss with the engine. I've probably got $15,000 in parts and labor in it on top of the cost of the car. If I could get somewhere close to 8k for it I'd pull it off the auction block.
Good luck with the sale, a very nice car indeed. I am a little curious about the headlights though, is that stock or after market?
Wasnt Sold !
Im sure you got tons of nonsense offers , just curious , i wasnt following auction what was high bid >>>>
Im feeling this DCM should be submitted in ROTM !!!!!
unless your leaving that up to the new owner !
