GONE is one used box, quick-ratio. ACDelco pn 36G0134, same as GM 19321389. Listed for Impala, 9C1, Roadmaster, fit Fleetwood and Custom Cruiser as well--any B/D body, and tons of other GM cars. Three-bolt mounting, with the modern ¾”-30 spline input shaft size and our captive O-ring hose fittings,but you can put them in pre-1977 by using a different rag joint connector and putting flare adapters in the hose fittings. No damage to the output shafts, no evident external leaks. Both boxes work but are sloppy and should be rebuilt and adjusted before installing.
Each one is 29 pounds shipped, dimensions listed in the pics. $50 each for local pick-up, zipcode 28782, or $75 each including UPS ground shipping to lower 48 states. PM me for Paypal info.
Box 1 sold
Box 2
199097
