1 - 10 of 10 Posts
Car is a '95 LT1 9c1. I'm used to 1/2 a tank on the gauge actually being 1/4 a tank, etc.. but the gauge is showing considerably more fuel in the tank than normal.
This occurred on typical mountain roads, so fuel sloshing may have been an issue- but i'm now back in the city and still having the same issue. There is currently about 1/8th of a tank (according to 'typical' gauge readings) but the gauge is showing 1/2 a tank at most times. It will occasionally drop down to the 'true' level for a few moments but return back to half.
I've heard of a few Techron fill-ups correcting issues like these- if it is just a gunked up sender or something... or do I have another issue? Not sure if the low fuel light actually works, don't need to burn out my fuel pump.
Thanks fellas
The sender should read 0 (low) to 90 (high) ohms. You can check it at the tank connector. It could be a dirty contact in the connector, or the instrument cluster as well.
Wasn't able to get a reading from the tank connector with my DMM, probably doing it wrong.
The fuel gauge pegs to F if I unplug the connector, though. Cleaned them off with rubbing alcohol and a q-tip, they did not look abnormal.
Reading F with the connector off is normal. Higher resistance more fuel. Disconnected = maximum resistance. You will probably have to pull the tank. The wires for the sensor in the tank should be purple and black.
Not much experience with DMM's. found some info from an old cache'd post-
Here's a test you can do w/o dropping tank:
Borrow a DVM if you haven't got one, and set to Ohms.
Unplug rear gas tank 3 Wire Harness connector, and touch one probe to Cavity A(Black wire) & the other to Cavity B(Purple wire).
If reading is Zero, there's an open in intank Float Rheostat Circuit = Drop tank & look for open/faulty Rheostat Ground spade connection
But, first remove harness loom, to examine whether Purple is cut/broken under der.......
do I do this with KOER? and am I probing the tank or body side of the harness- or tank harness-to-body harness? Please bear with me here.
Thanks Fred.
Thanks Fred.
The car should be shut off. It would not run anyway if you disconnected the connector, because it is also the power for the pump. You are probing the tank side of the connector, and looking for a reading in ohms. 0 is empty and 90 is full. If it is over 90, or high for the amount of gas in the tank, the float is probably not hooked to the potientiometer arm properly, or the arm is bent. You stated that it worked properly before the mechanic touched it, and did show some motion since, so I would assume that the arm is not connected properly. You can check until you are blue in the face, but you are eventually going to have to pull the tank. Make sure the tank is near empty when you pull it.
Discussion Starter · #7 · (Edited)
The pump/strainer assembly hasn't been touched since i've had the car. Haven't had any fuel related issues in those 15 months either.
Just trying to figure out what's going on before I get stranded, and i'd rather not have to replace anything just yet that doesn't need replacing.
Discussion Starter · #8 · (Edited)
That was retardedly easy. Got a reading of 50.3 ohms, though 5.03 ohms sounds about right for the amount of fuel that should be in the tank....
Discussion Starter · #9 ·
Put in 13 gallons- was bout empty. Gauge is pegged past Full, and I got a reading of 94 Ohms.
I think you may have gotten my post confused with someone elses, Fred cwm5
1 - 10 of 10 Posts
