When I gas up my Wagon 7 days before, the fuel needle shows more than Full.
After 40 miles the needle shows half on the last quarter of the indicator.
2 days before I gas up my wagon again and today I have 20 miles on my speedometer...and now I come to the problem...the fuel-needle shows again half on the last quarter!???
Is that normal???
My driving style has been unchanged all the time.
All miles are driven in town with 30-40 mph and much stop and go´s.
Often I think that my mpg is different every time I gas up the car!?
My mpg in town with "D" gear is sometimes 13-14 and sometimes 10-11.
On the Autobahn with 75 mph on cruise control and "OD" is 18-19 but sometimes 17 too.
I don´t know what´s wrong...It´s a pitty that there is no scangauge for OBD I to check & control my mpg.
The car has 89000 miles on the clock, almost driven in germany (I think with much town-miles).
Every 6000 miles the oil was changed with 10W30.
I read about the 5W30 Royal Purple oil in the past topics and I drive much in town, so is it advisable to change my oil in future with that Royal stuff to get a better mpg???
Maybe you can help me in my problem!?
I hope so...
Piot
[ 06-26-2007, 11:41 PM: Message edited by: piot23 ]
I don't know if the Caprice has a low fuel indicator light. I use the light on my dash and the mileage more than my gauge. When I fill mine it will go about a quarter of a tank past full. As I drive it will stay on full for a long time then it will fall to past half a tank almost overnight. There are several fixes for the gauge this seems to be the easiest:
Fuel Gauge fix
If you slow down to around 70 mph with the cruise you should see 20 MPG, I know this is slow on the autobahn but it is worth it to save Euro.
Hi Piot,
It is common for the gas gauge on these cars to be faulty or incorrect. As mentioned, there are various fixes. I used the fix mentioned by UberWagon....it's cheap and helped my gauge to work better......but it's not perfect. The only true fix is a new fuel sender, in most cases. Your MPG doesn't sound bad.....mine is about the same (14 in city, 18 on highway).
Thanks...I´m happy, thats the fuel indicator is incorrect in these cars is normal.
Do you have test these royal purple oils to get better mpg in your cars?
I can vouch for the fuel sender fix described by UberWagon. My needle falls like a feathery stone, as opposed to a 8-ton slab of granite now.
My 'half' indicator is more like a 3/5ths reading as opposed to a 2/3rds reading.
