it holds steady when I switch the ignition key to off. what do I check next.
If that is the pressure with the ignition on then it is too low.
hard to start, runs poorly, cuts off when I press gas, just trying to find the problem myself before I take it to chevy service center, two shops have not b.een able to find problem
Sounds like the fuel pump, pressure regulator, or fuel filter.
