still trying to find out what my issue is with intake backfire
yesterday i tested fuel pressure
just key not running 22psi
car idling 35psi
revving engine 43psi
idle but vac disconnected 45psi
car off and left off for 5min 36psi
items changed so far
new plugs/wire
cap and rotor
fpr new
junk key no run 22psi
car idling 35psi
new plugs/wire
cap and rotor
fpr new
That's what most of us get with old pumps. 22 psi is low, but check the battery voltage. When it is 12.6 V it should be around 40 psi. If it i still 22 psi, your wiring or fuel pump is not good.
My fuel systems holds zero pressure,and has for many years. Doesn't affect the cars running operation even a little bit.
when you turn key on/engine off the FP gauge should immediately snap up to around 42-44 PSI for a few seconds (pump is priming) and then drop to around 36-38 (pump stops priming)
22 psi suggests the pump is weak or fuel filter is clogged...or possible high resistance in wiring connections to/in pump assembly knocking VDC down to low volts
The RA link you posted is the pump sender assembly....does not look like the pump itself is in it...unless I am missing something
