roughly where does it need to be? 396 cid afr heads cam 255 pump 42lb injectors adjustable regulator
6 6secimpala · Registered Joined Oct 11, 2010 · 4 Posts Discussion Starter · #1 · Oct 13, 2010 Only show this user roughly where does it need to be? 396 cid afr heads cam 255 pump 42lb injectors adjustable regulator
Mean SS · Registered Joined Nov 17, 2002 · 991 Posts #2 · Oct 13, 2010 Only show this user 43.5 lbs with the vacuum line to fuel pressure regulator plugged
