Just wonder IF there is a gauge that ya can screw on the fuel rail, that will give a signal to a digital gauge pressure readout??
I have seen the little say 6 or 8 inch piece of piping/fittings with a fuel gas fluid pressure gauge but they were reading form 0 to 100 , and thought either a digital readout or IF ya can get a mechanical gauge to read from 0-60 more accurate yes???
I bought a mechanical FP guage from the local parts store right off the shelf - about $30 or so. It screws right on the fuel rail schraeder valve.
Reads 0-100 but it's not permanent. it's one for testing and diagnosis. If you want a permanent gauge to put inside the cab, you will need an electric one or a mechanical with an isolator. You don't want fuel running inside the cab.
LoL Your right there.... No JUst thought there was one out there one could leave hooked up, But after I think about it , Its easy just to hook one up for checking pressure less things to leak and go wrong...KISS Method works...
Not to mention they are about $200!!!
