how much harder is is to change wheel bearings on a fwd car?
need to help a friend and just wanted to ask...
thanks guys...
It all depends on the car. Some just need a hub puller to get the hubs off the axle and then you change the entire hub assembly, pretty easy. Others, you have to pull the knuckle off, and have a new bearing pressed on at a machine shop. Others are somewhere in between.
