...will not fit. They fit the engine just fine, but they do not clear the washer motor as well as the heater core ports on the firewall. Yes, I know the originals will fit, and I HAD the composites on here - but both sides developed cracks around the bolt holes and started to leak. More than likely, due to being over-tightened over the years.
Next up: Proform 141-845.
I'd hazard a guess that it isn't, but I'm not shy about breaking out the dremel and going to work on the alternator housing. Rumor has it that it only takes a little bit of grinding to make them work
