1 - 10 of 10 Posts
Camaro, Firebird, Corvette late GM 12MM THD .509 knurled Dia. wheel stud kit part# 100-7708...........i have 2kits $21 shipped
I think these are the correct size for b-body also.
Chrome 396 emblems $35 shipped
I just used 3m double sided tape on the back side.
Roush biege floor matts $35 shipped
Sweet exhust tips that come with the clamps $70 shipped per pair.
93-02 Firibird passenger mirror $40 shipped
OK now don`t you guys fight over these.....but i do have a few.
New 05+ Roush 427r Mustang hood scoop with the grill. No hardware but you could just use 3m double sided tape and not drill any holes. oorrr buy the u shaped clips and screws ??? $65 shipped
Roush f-150 hood scoop $75 shipped..No hardware but you could just use 3m double sided tape and not drill any holes. oorrr buy the u shaped clips and screws ???
There for the f-150..........i have a set in my 96 Caprice and the fronts fit nice but the backs were too big.
You Know You Want Those Chrome Tips :~)
turkey mmmm
you know you want that emblem :)
Discussion Starter #7 (Edited)
New LT4 Edelbrock Intake
New in the box $425 shipped firm
http://i51.photobucket.com/albums/f393/bigcowl-imp/3507109.jpg[/IMG
The Edelbrock Performer RPM Air-Gap LT4 intake manifolds feature a tunnel-ram design that offers performance increases in the 1500-6500 rpm range. The air-gap design separates the runners from the hot engine oil, resulting in a cooler, denser charge for more power. The 350-7109 is designed for 1994-95 LT4 engines. The 350-7109 will also fit the 1992-97 LT1 engines that have LT4 style cylinder heads. The 350-7109 is port matched to the LT4 cylinder heads (350-61939). It may also be used with our performer LT cylinder heads 350-61909, with minor port matching of the cylinder head recommended for optimum performance. This LT4 manifold will accept stock or aftermarket fuel rails and include an OEM style throttle body pad that will accept oversized throttle bodies up to 58mm.
Sold.......
i geuss not :(
Do you still have this manifold??
Has this been sold yet??
The Edelbrock Performer RPM Air-Gap LT4 intake manifolds feature a tunnel-ram design that offers performance increases in the 1500-6500 rpm range. The air-gap design separates the runners from the hot engine oil, resulting in a cooler, denser charge for more power. The 350-7109 is designed for 1994-95 LT4 engines. The 350-7109 will also fit the 1992-97 LT1 engines that have LT4 style cylinder heads. The 350-7109 is port matched to the LT4 cylinder heads (350-61939). It may also be used with our performer LT cylinder heads 350-61909, with minor port matching of the cylinder head recommended for optimum performance. This LT4 manifold will accept stock or aftermarket fuel rails and include an OEM style throttle body pad that will accept oversized throttle bodies up to 58mm.[/quote]
1 - 10 of 10 Posts
