I got a gearbox from da dealer ,how hard is it to install!? Am i better off having sum1 else do it? Looks kinda easy!
It's only 3 bolts on the frame, but the ABS deal is in the way making it a little tougher. Overall not that bad of a job though.
It's a little more than just 3 bolts... but it's not bad.
You will have to remove the steering shaft first.
You'll have to also pull the pitnam arm off the old one and re-install it on the new box.
Removal of the fluid hoses can be fun... especially if it's a high mile car. I had to use a torch to heat mine up before they would break loose.
