Hello! If I buy a gen 1 350 rebuild kit, will it work fine on a LT1? With the exception of head and intake gaskets obviously.
Asking because LT kits are much more expensive for some reason.
Thanks!
So that kit , all you are going to use is
main bearing,
rod bearings,
rear main seal ,
front crank seal ,
oil pump
Then buy
rings that fit
Head gaskets
Intake gaskets,
Rocker gaskets
Front cover gasket kit
Etc, etc
If you are comparing to
Although twice the price,
It also has pistons
Along with gaskets that fit.
Now, I an not saying that "kit" is good or bad, just noting why it is twice the price,
Plus the kit you linked, your would throwing half of it away.
Apples and oranges comparison
You get what you pay for .
Okay thanks! I didn't know how little interchanged.
