1 - 9 of 9 Posts
Ok, i need some help w/the NX GENX-2 bottle heater. I'm pretty sure i got it right, but please someone verify
Relay:
Green wire to white wire on heater
White wire to ground
Red wire to one side of transducer (does it matter which side?????)
Black wire to + On battery
Heater itself:
One white wire to green wire one white wire to ground
Transducer
One side red wire
Other side of transducer to switched 12V
Thanx a lot fellahs
Is there any other way to view the diagram? everytime i try to go to it my computer freezes and i have to cut it off, very annoying, i think it's because i don't have the adobe program thing. But if ur using the factory GENX kit it should be the same as mine as far as the relay wire colors go. Thanx.
It actually helps out a lot...so instead of the red goin' to the transducer, it's goin to a switched 12V, so which ones go to the transducer? Sorry for all the questions, but i gotta get some more pressure!
The +12 is what controls mine.
Ok, so 85 on relay goes to one side of transducer, other side goes to 12V...I think we may have it...thanx a lot!!!
That would be 87. Take a closer look.
30= 12v (main power)
86= 12v switched (low power)
85= Ground
87= 12v out (main power)
On mine 87 goes to transducer then straight to the heater.
1 - 9 of 9 Posts
