1 - 10 of 10 Posts
ALL ITEMS $10 OR LESS. ANYTHING LISTED AS $FREE PAY SHIPPING ONLY WITH PURCHASE OF $10 PART OR TWO $5 PARTS. Okay, so I added a couple that are more than ten, sorry.
Guys, my garage is basically full due to having too many projects going on and hoarding too many parts. I've got to get rid of stuff. I'm going to slash prices hoping to get SOMETHING out of these parts. If I have anything in 60 days, it's all going to the scrapper.
ALL PRICES NEED SHIPPING ADDED!
MULTIPLE ITEMS ARE PRICED PER EACH!
BOLTS NOT INCLUDED!
NEW ITEMS!!
OBD2 Reluctor ring - $10
OBD1 PCM - $50
Camaro accessory bracket - $10
Stock oil pumps - $5
(2) stock crankshafts that both need turned - mileage unknown - $10
(2) sets of stock bore pistons - one with 75k, one with 175k - $10
Water pump w/ ECT sensor - $10
Bad stock head (some valvetrain parts?) - $5
Full valvetrain set (valves, retainers, locks, rockers, studs, etc.) - $10
TPS throttle position sensor - $5
IAC solenoid - $10
(2) kinda banged up oil pans - $10
Set of lifters (if I can find retainer clips) - $10
F-body starter - $10
Water Pump Temp Sensor - $5
Head Temp Sensor - $5
Frame Mounts - $10
Motor Mounts - $10
Crank Balancer - $5
Windage Tray - $Free
Camaro A/C Hard Lines - $5
EVAP Solenoid - $Free
'94 Impala SS Cam - $5
Rear Main Seal Holder Plate - $5
AIR Bracket and Pump - $5
AIR Hard Piping That Goes Under Motor - $Free
Oil Pan Rails - $Free
Oil Pan Bolts - $5
Opti Vent Tubing - $10 (I might be out of these)
EGR Solenoid - $Free
OBD2 Crank Position Sensor - $5
PCV Tube (needs new rubber hose) - $Free
Oil Pump Driveshaft - $Free
MAP Sensor (no grommet) - $5
4L60E Flexplate - $5
Oil Pressure Sensor Elbow - $5
B-Body Oil Pressure Sensor - $Free
Stock Timing Set - $5
Stock Hardened Pushrods - $5
Oil Filler Tube - $10
Ask me about bolts for longblock parts, I may have them (oil pan, timing cover, opti, motor mounts, TB, etc.)
SOLD
Water pump gear drive
Lifters & dog bones
Cam retainer w/ bolts
Rockers
Set of pushrods
OBDI F-body balancer hub
Rear main seal holder
Valve covers
Windage tray
Timing set
Throttle body w/ sensors
AIR pump w/ bracket
EGR diaphragm, solenoid, tube
EVAP solenoid
MAP sensor
IAT sensor
IAC solenoid
Opti vent tubing
Good stock head w/ valvesprings only
Intake w/ MAP sensor, NO fuel rails
(2) power steering pumps
B-body OBD2 hub for Balancer
'93 22# Injectors
'94 Timing Cover
Valve Covers
T56 Slave Cylinder
Oil Filter Adapter for Cooling Lines
B-Body Offset Oil Filter Adapter w/ Oil Line Port
Tensioner Pulley
Tensioner Pulley
Pair of OBD2 Knock Sensors
Oil Dipstick w/ Tube
PM sent. Thanks Hector.
Discussion Starter #8 (Edited)
BOLTS NOT INCLUDED!
F-body oil pressure sender - $10
IAC solenoid - $10
Crank Balancer - $5
Oil Pan Bolts - $5
SOLD
Lifters & dog bones
Rockers
Set of pushrods
Valve covers
Windage tray
Timing set
AIR pump w/ bracket
EVAP solenoid
MAP sensor
IAT sensor
IAC solenoid
Opti vent tubing
'93 22# Injectors
'94 Timing Cover
Valve Covers
T56 Slave Cylinder
Tensioner Pulley
Tensioner Pulley
Rear Main Seal Plate
Recycled:
Frame Mounts
Motor Mounts
Pending Sold:
(2) OBD1 PCM's - $30 each
1 - 10 of 10 Posts
