I thought it may have been a burnt bulb but when I replaced with a new one, the light still didn't work. Wires look ok and I jiggled them to see if the contacts with the connector were loose but still no workie. I was going to check the fuse but couldn't find which one the glove box is wired through. Scratching my head on this one.​
Courtesy lights (I believe)...
A few:
See can you disassemble the switch for anything corroded/broke/worn.
If not takeapartable then some spray elec contact cleaner
If nonathat then glop the switch full of dielectric grease and cycle 100x
Or, try to order a new switch
You didn't list your car, but some Cadys/Buicks have extra special CCM (I think Computer Convenience Module?) that controls many of the options and cause wonky symptoms when going south (though I can't believe they'd include the glovebox light on it). In any case check around for any other lights not working that might give hint of upstream circuit for more burnt fuses.
How 'bout checking for power,and ground presence before screwing with switch.
Banned
you fix the pass key mess ? what about the glove box ///. what is going on ?
