Hello! Where can I get a cable to program my OBD1 swapped 96 caprice? I swapped in an OBD1 puter but kept the OBD2 port. I'd really like to not have to spend tons of money on a special OBD1 pinned OBD2 cable.
Or can I just mutilate a usb cable and make that work?(just stick the wires straight into the pins).
My answer to this question will be that you should try to support TunerCAT.
My 1st reason is that I do not know where you would get it for less - and there is always the risk of counterfeit FTDI chips that have been obsolesced by new drivers.
My 2nd reason is that TunerCAT is still discovering and organizing new tunable switches and constants and tables for our OBD1 LT1 $EE definition file after 26 freaken years later.
In your case you may have to contact him for the specific type of cable you want made.
I have a OBD1 cable already, but my car has an OBD2 port still. Could I just swap the port for an OBD1 port and use my existing cable?
Get a spare obdI connector from a car I. The junk yard. Wire up the 2 data pins and soldier some straight length of paper clip to the other end. Jam the paper clips into the obdII connector as needed. This is what I had for a long time. I eventually replaced my underdash connector with a 1/4inch mono stereo plug.
-Brian
-Brian
Not sure I understand what part the paper clips play.
