1 - 14 of 14 Posts
Hey guys..... I've wanted a caprice for the longest time and I think my time has come.... after the most recent trip to the dealer to have repairs on my ZR2 Blazer, I've decided I'm going to try to trade it in for a caprice at the dealer ship..... can you guys tell me what your opinion on this is.
1995 CHEVROLET CAPRICE CLASSIC: 8CYL,AUTO,AC,PWR WIN&LOCKS,CRUISE,STEREO! ONLY $7995
Options Installed
Air Conditioning; Alloy Wheels; Cruise Control; Rear Window Defroster; Power Door Locks; Power Mirrors; Power Windows; Power Steering; Tinted Glass; Tilt Wheel
Features
Exterior Color: Green
Interior Color: Grey
Doors: Four Door
Body Style: Sedan
Transmission: 4 Speed Automatic with Overdrive
Drive Type: 2 wheel drive
Engine: 8 Cylinder Gasoline
Fuel Type: Gasoline
Stereo: AM/FM Stereo Tape
Stock Number: 21225A
VIN: 1G1BL52W9SR153904
I know it's the 4.3, but to be honest, I'm not really looking for something to be fast, just something with a little umph. also, I read that the BL in the 4th and 5th characters on the VIN means it's the police package, is that true? If so that means it has a beefed up suspension right? here's a pic
How many miles does it have? I found my 95
Caprice 9C1 with the LT1 for $4000 it has 94496 miles on it but it runs great plus with the LT1 you have all the power and speed you want. the only difference mine is to that one is that the other one has alloys. If i were you i would shop around for a while first. It took me a while to find mine but when i did it was all worth it.
It is NOT a police package, and has the 4.3. It is a good factory color (inside and out), but it is still overpriced in my opinion. It depends on what else is available in your area. If this is a trade-in at a dealership, they didn't pay more than $2200-2500, so I would work 'em hard to bring that down to about 5 grand. I've worked in dealerships for years, so that *ahem* should be reliable info. Here's some more info:
VEHICLE INFORMATION
Merchandising Model: 1BL19 - 1995 CAPRICE CLASSIC SEDAN Warranty Start Date: 11/04/1995
Delivering Dealer : TRENOR MOTORS, INC.
PO BOX 108
URBANA, OH 43078-0108
(937) 652-1371
CAMPAIGN ELIGIBILITY
95071 STEERING COLUMN TRANSMISSION SHIFT CONTROL ADJUSTMENT N/A Closed
96010 LOWER CONTROL ARM BALL JOINT N/A Closed
CLAIM HISTORY
02/09/1998 270945 # C0182 - RIGHT FT DOOR WINDOW (POWER) R&R OR REPLACE. 23317 miles
11/14/1997 263047 # C0183 - LEFT FT DOOR WINDOW (POWER) R&R OR REPLACE. 21384 miles
06/03/1997 017172 S E0201 - BALANCE TWO WHEELS 15001 miles
05/29/1997 017039 # K7020 - TRANS CONVERTER RPL 15021 miles
05/29/1997 017039 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 15021 miles
05/29/1997 017039 # J4520 - DISTRIBUTOR R&R 15021 miles
05/29/1997 017039 # J4206 - SPARK PLG WIRES RPL 15021 miles
05/05/1997 016822 # C8817 - SDM MODULE RPL (SIR) 14639 miles
08/02/1996 013358 # C4640 - RR FLR TRIM R&R/RPL 9627 miles
04/19/1996 011704 J V9865 - 96C14 LOWER CNTRL ARM BALL JOINT-INSPECT 5988 miles
02/09/1996 010701 # J4640 - MOTOR STARTER RPL 4011 miles
12/29/1995 010119 J V9800 - 95C61B-CAR STEERING COLUMN TRANS SHIFT CONTROL ADJUST 3066 miles
04/13/1995 006424 I Z7000 - NEW VEHICLE INSPECTION ALLOWANCE 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating: 2343 kg (5166 lb) Order Number: 13579K
Build Date: 03/27/1995 Build Plant: 1SRB - ARLINGTON ASSEMBLY PLANT
OPTION CODES
AA7 AK5 - SEAT, INFLATABLE, DRIVER & PASS
AM6 - SEAT - 60/40 SPLIT FRONT BENCH ARL - ARLINGTON, TX, USA
A90 - LID, REM CONT ELEC RELEASE C49 - RR WINDOW, ELECTRIC
C60 - AIR CONDITIONER FRT, MAN CONTRO DG8 - LH & RH, REMOTE CONT, ELEC, HEA
DL5 - ROADSIDE SERVICE INFORMATION FE1 - SOFT RIDE
FE9 - FEDERAL EMISSIONS GW9 - 2.93 REAR AXLE RATIO
IQG - INTERIOR DESIGN (QG) JA1 - LIGHT WEIGHT, DISC/DRUM
JM4 - ANTI-LOCK BRAKE SYSTEM K34 - CRUISE CONTROL
K68 - GENERATOR L99 - 4.3 LITRE V8 MFI
MX0 - 4-SPEED AUTOMATIC TRANSMISSION M30 - 4L60 AUTO TRANS
NA5 - EMISSION SYSTEM, FEDERAL TIER 0 N30 - DELUXE
N40 - POWER, NON-VARIABLE RATIO N81 - FULL SIZE
PB1 - 15 INCH PH1 - STYLED WHEELS
QCV R7A - SALES ITEM NO. 26
R8S - SALES ITEM NO. 68 R8T - SALES ITEM NO. 69
UM6 - RADIO - AM/FM STEREO WITH UQ1 - PROVISIONS, AM/FM STEREO
UQ5 - 4, DUAL FRT DR MTD, DUAL EXTD R U02 - INSTRUMENT CLUSTER
U73 - FIXED ANTENNA VK3 - FRT MOUNTING PKG
VM3 - CONSUMER, CONTAINS BPR IMP STAN V73 - USA/CANADA
1AY - STOCK 1SL - PREFERRED EQUIP. GROUP - 1SL***
14G - CLOTH, LT GRAY (G) (94). 14I - VERY DK GRAY (I) (97)
18Q - DK GREEN GRAY MET (92) 18U - EXTERIOR, DK GREEN GRAY MET (96
6TD - COMPUTER SEL SUSP (6TD) 7TF - COMPUTER SEL SUSP (7TF)
8RZ - COMPUTER SEL SUSP (8RZ) 9RZ - COMPUTER SEL SUSP (9RZ)
I bought a 1994 Caprice, two years ago this month. It had 62,xxx miles. It has the LT1 all the power goodies except passenger seat. I paid $6,200. Last summer my wife got a real clean 1996 4.3 Caprice loaded, 65,xxx miles and I think we paid $6,500. Deals are out there, you just have to look.....
Steve
I'll second that, you can get an lt1 car much cheaper if you're willing to wait and you jump on a deal when it comes up. I just got my 95 lt1 9c1 a couple weeks go for $2000. Its got 140k miles and needed a little body work but its mechanically solid.
I will sell you my Civi Caprice for $5000... Its got the 4.3 but its loaded otherwise. Super clean condition and only 70k...
4
for 8k not even with an LT1?
Walk away from it. Wait and get at 75K mile lt1 for that price....
You may want it now and say it has good power, but you will need more for this big car in a hurry..
pass on it. IMO
There's a white civi 96 near me with like 56k miles and an LT1 for $7995. Pretty well loaded, no leather but everything else. Just thought i'd add this cuz this is the 2nd or 3rd post i've read about people not finding LT1 cars in their area. I feel this may be one of the last production ones cuz the vin is after mine (doesn't really mean anything) and it's white with burgundy interior which, to me, isn't the greatest combo. Weren't the last ones all white so they could put any interior in?
Sean
Mine is for sale.
Dark Green Grey Metalic 96 Caprice Classic LT1, fully loaded with every available factory option. Added SS 3.08 rear w/disk brake, SS body trim, and Trunk Spolier. Also the Blazer overhead with temp/compass. All that is needed to complete the SS clone look for the outside is a set of SS wheels/tires and SS springs. It just went over 100k during a trip from IL to NC.
I'm looking for around $7,500. I just looked in the Nassio Classified, and theres a 96 Caprice LT1/SS clone with 185K miles and he's asking $10,000. Also saw a 92 Caprice for $6,000. So I don't think I'm asking to much.
As for the last ones being all white,
My 96 DGGM Caprice was built on 11-27-96.
I have the 4.3 liter. I paid that 3 years ago for pretty much the same car.
I think 4500 to 5000 is an okay price.
But if you have that much to spend get a civi LT1 caprice.
Discussion Starter #13
I just got a 1995 4.3L caprice with 137xxx miles for $1200. I'm doing about $500 in parts to get it to start, but still...good deals are out there. Last month I found a 1991 Buick Roadmaster Estate wagon for $1400 and drove it away, needed nothing. I hope I don't find any more good deals for a while ;)
Steve
Discussion Starter #14
Well that one is definately out of the question now, not just because of the price, but the dealer...... That is where I bought my current vehicle... a 1998 ZR2 Blazer. It just recently went in for a warrenty repair, the spider gear broke into pieces. Well a week later, they finally get the rear end re-assembled and take it out for a test drive the transmission started sliping. This will be the 2nd repair the the trannie in less than 6 months. I now don't feel comfortable buying any vehicle from them. So the hunt is on.....
1 - 14 of 14 Posts
