1 - 11 of 11 Posts
96 Black SS
The time has come to put our 96 up for sale. I need to bring another project car home and do not have space for two muscle cars. A little bit about the car, I have owned it for about 15 years, and performed most all the work on it. At the time I used to own my own machine shop. The engine has been built from the bottom up. The car had always intended on being naturally aspirated. At the time I was intending it to race the naturally aspirated stock bottom end heads and cam class (way back when). The bottom end is a stock 350 that has been blue printed balanced. I know that saying is cliche so here is what is done to it:
Stock bottom end Crank, rods and pistons.
Pistons flycut for 2.080 intake valves.
All meticulously balanced.
4 bolt lt4 block main studs, line honed
Custom grind cam (will get specs on request)
Short travel hydraulic roller lifters.
AFR Heads ported and polished in house.
Holley Stealth RAM adapted for use with the LT heads.
42lb injectors
Dual high flow fuel pumps.
Anti slosh fuel reservoir for autocross
SPARE SHORT BLOCK
I also have a 398 CI rotating assembly
Callies Crank,
Lunati H-Beam Rods,
Wiseco Pistons.
Block has billet main caps
11.8-1 compression with the AFR heads.
Suspension:
Adjustable QA1 shocks in front,
High rate springs
Tubular upper control arms
Front and rear sway bar
Extra set of powder coated gun metal gray impala rims, used for Autocrossing.
Exhaust
Long tube headers
Shorty catalytic converters
X pipe
Magnaflow mufflers
Side exit pipes.
I will be adding more pics as the time goes on to the google drive.
Car is sold as is. off highway use only.
Please Message me if interested. I am asking $5k open to negotiation Cash / cashiers check.
96 SS - Google Drive
96 Black SS
Added some more pics to the link. Also forgot to put the car is in Socal, near Palm Springs area. If anyone is interested. (y)
Yup, miles, interior pics, and will it pass smog test?
Off highway use only? Does that mean unregistered with DMV? Or PNO?
Clear title?
96 Black SS
Sure nice of you to answer the questions I asked. :rolleyes:o_O
  • Like
Reactions: Sinister
96 Black SS
Clear title?
Sorry, I am on vacation, I just saw this post.
It will not pass smog. It has long tubes, small cats, big cam etc. It is non-opted, clean title. I don't recall the miles exactly, I will post them when I get back. I also just got it running again before I left. I will take a video and post it to the drive along with interior pics when I get back this weekend.
Thanks!
  • Like
Reactions: cappy p
96 Black SS
Yes, it is. I have more pics I need to upload to the link. I also got it back running . I will upload video to hear it run Sunday. (y)
1 - 11 of 11 Posts
