D
the bmr rear lower control arms i just got have grease fittings... what kind of grease to use?
i have a grease gun filled with some kind of brownish grease, i wonder if it's ok to use...?
A
If the grease gun has the stuff you'd use on the front suspension, then it'll be fine for the BMRs.
I like the Mobil1 Synthetic grease myself.....it's only pennies more per lube job than the cheap stuff, plus it's red when going in so it's easy to tell what is new and what is old.
