Hi,I have a 96 SS and my fuel gauge reads 1/2 full when full and my odometer doesn't work.Are they tied into together on a circuit.I seemed to remember somebody at one time had a kit for the fuel gauge where you splice a wire into fuel sender wire under the carpet by the front drivers seat and you could dial in the resistance going to sending unit.?? Thanks,Tom
Without checking the FSM I don't believe those are on related circuits. I'd say you have two separate problems. The odo is a common problem. Check the sticky on the Interior subject area.
The fuel gauge is most likely a float/sending unit problem.
