I can build a motor faster than I can understand this HID stuff !!!
So I get clear lenses on ebay, ok, now I get a projector and a 9004 HID kit?
and that does the high-low beam ? but I have to mount the projector on the clear lenses.
I'm still scratching my head.
maybe I'll get a sylvania ultra 9004 and spend the rest of the day watching the game.
and I'm still confused because my Charger with factory HID's has a 9005 for the high beam.
Probably because the high beams are not HIDs.and I'm still confused because my Charger with factory HID's has a 9005 for the high beam.
I like that. cwm2"Putting HIDs behind stock capsules is the equivalent of putting on somebody else's eyeglasses: You can probably make them fit on your face OK, but you won't see properly."
My cheap ebay set up has worked for the last 5 years. I only changed the bulbs for brighter 6000k ones for the whiteness. I had 8000k and got tired of them.On one of my last Mustangs (97 GT convertible), i installed a cheap $70 HID 6000k kit i got on eBay. The quality sucked, sometimes one of the headlights wouldn't come on all the time, so i always had to play with it. Stay away from the cheap ebay HID kits, as they have cheap ballasts, bulbs, etc. I'd say spend a few hundred bucks and get a quality HID kit.
I only wish we had a better choice of projector headlights that did not come at such a ridiculous price as many have been selling them for. I mean seriously! 1000$ ?? No thanks.
Quality aside, I'm assuming they work a lot better than stock and still better than the HID kits?You could also get on ebay and get a 9004 Bi-xenon projector kit. $200, and they're actual projectors and they have a lock ring, that you put the projector into the 9004 socket, and there's no cutting. Not as good quaility wise as an OEM projector, but they're less $$$
Not sure how you didn't notice a difference in your truck with HIR bulbs. Practically everyone that is able to capture pictures of the swap shows a good amount of added light, and there should be, at over 1000+ more lumens than the 9005/9006 bulbs put outI have been experimenting with everything EXCEPT HID's. The Sylvania ultra's are no better than factory OEM 9004 lamps that are 15 years old. Wasted money on those.
I tried HIR's in my truck. They are no better than old 9005's.
I also tried the Hella's blue tinted light. throws a different color, but doesn't light up the road any difference.
The only diffinative difference is HID's which came stock in my other car.
The new caddy platinium has LED headlights, reviews say less light output than HID's on the low level caddy.
I can speak for the DDM tuning kit. No adapter or harness is necessary.
Without ordering any extra parts, they have everything to hook them up. Their own relay that gets its signal from one of the headlight sockets and a fused lead that goes to the battery.
The hi/low kit has a little extra wiring, but still comes with everything needed.
Also FWIW, I went with the 4500's and have been utterly pleased with them.
HTH
Scoob so you don't need the dual in and dual out harness if you buy a kit from them? As they include a wiring harness that draws power from battery?
No you will not need any adapter or harness. Sometimes the DDM kits have reversed connection pins on the plug but that is not a problem to correct
SO IF WE BUY A KIT FROM DDM tuning WE DONT NEED an adapter or harness???????
thanks!no you will not need any adapter or harness. Sometimes the ddm kits have reversed connection pins on the plug but that is not a problem to correct
im having the same problem. what would cause that problemI think I might have to re do the set up of my DDM HIDS...because the driver side light is brighter than the passenger side light..not sure what the problem could be!
