1 - 13 of 13 Posts
Hey what's up guys I'm new here just started fixing up my caprice but running into lil engine problems and need some help but I'm only 20 and on a budget so ineed the cheapest but most thoughrough way out of this problem and I don't like taking my cars to shops I like getting dirty.. so here's my problem right now in the mornings or when my car sits for a couple of hours it takes a long time to start it.. It cranks but doesn't start till after like 6 or 7 cranks help plz people..
If turning the key ON a few times before starting the engine helps, then you most likely have fuel delivery problem. It can be either the pump or fuel pressure regulator.
Pull the vacuum line off the nipple of the fuel pressure regulator (on the fuel rail) when the ignition is ON. If there is fuel in the hose or dripping from the nipple, your FPR needs to be replaced.
Measuring fuel pressure is always helpful.
Most likely the anti-drain back valve in the pump is gone, turn the key on several times to let the pump prime up, then turn it to start. The fix is a new pump....mine lasted about 18 months before the pump died.
Discussion Starter · #13 ·
thanks everyone who helped it ended up being the fuel pump the pressure was down so the anti drain valve so I got it done and now I starts great next step is dual flowmasters hopefully tomorrow..
1 - 13 of 13 Posts
