1 - 15 of 15 Posts
Get aluminum if you want performance. Get cast if are going to use it as a daily driver. You dont want aluminum heads on a hot day sitting in traffic.
Are they gonna melt?
WTH..no
Aluminum has different heat characteristics than the cast iron head. Some say the difference between the aluminum and iron block can cause blown head gaskets...
WTH..no
True. I have never heard of anyone with iron heads blowing head gaskets. but I have heard of camaros and trans ams blowing head gaskets.
1. If you're gonna get this engine, get the aluminum heads. Anyone who tells you differently shouldn't be giving LT1 engine advice :cool: !
2. I've heard this guy does good work but I wouldn't buy a 383ci LT1 that had a cast Eagle crank. But hell.....that's just me.
3. Heads have virtually no work done to them. Not a bad thing but really.....not a good thing, either. Just know that you'll leave a lot of power on the table.
4. BTW.....I ain't buying his power claims (stock heads with the CC-503 cam).
5. By the time you make the proper 'upgrades' that this guy will charge you for, you may be better of going else where ;) .
KW
Discussion Starter · #7 · (Edited)
KW
I'm not gunna do any upgrades I'm really just looking for for a new motor that puts down decent power and daily drivability for the price
And The valves are bigger arnt they 1.96s doesn't stock have 1.94s
He says I can get 3 different cams if I want but I'd like a mid range cam
......And The valves are bigger arnt they 1.96s doesn't stock have 1.94s......
A three-angled valve job on slightly larger valves is nice......but still, the heads haven't seen much work.
I'm not gunna do any upgrades I'm really just looking for for a new motor that puts down decent power and daily drivability for the price.....
Well.....this engine (IMHO) should fit the bill ;) !
KW
Discussion Starter · #9 ·
KW
Sounds good thanks
Idling in traffic does not cause head gaskets to fail. Aluminum heads run cooler than iron heads, so I am having trouble with that line of logic.
I hear ya ;) !!!!
KW
1 - 15 of 15 Posts
