Howdy everyone, I have a 96 impala that I plan on throwing in a built 03/04 tranny out of a Silverado. So far I have also gotten a reinforced input shaft, bellhousing, and stator support designed to fit to the lt1, and an adapter to allow me to bolt the old tail housing on to maintain the factory mount. I am prepared to do whatever it takes to make that damn thing fit; I am curious if anyone else has done this before, or if I am sailing into uncharted territory. So far it looks like all the dimensions line up well, but I have not found any articles that really make mention of this kind of swap. Thanks in advance!
The problem is how are you going to program PCM to operate it?
1995 was a stand alone year (trans.wise)...
Thankfully it's a 96 not a 95, console shifter and all. Unless the 96s are also subject to that issue too. I'm hoping there is little to no difference electrical wise from 96 up.
Have no idea ,good luck....
Why? Just use a 4L80E.
Can you explain?
I know that 95 was a standalone year, but I'm not sure what you're getting at as far as tuning.
I misspoke... Poster has a '96 ,and not a '95....
Super Moderator
If you're talking about using a 4L60E, I think you're 80% there. Keep up the good work, and you should be fine.
