Here's how it began...took out front d/s brake bolt(brake line) while doing suspension work. Put it back together and bled it. Pedal still goes to the floor...Found the copper brake bolt washers were leaking, installed new ones and that stopped the leak, rebled, and still goes to the floor. Repeated process multiple times just to be sure it was bled completely. Oh and yes, i did refill reservoir
Is it just bad timing that the master cylinder is bad???
