1 - 9 of 9 Posts
ok i'm lookin through the "how to rebuild lt1 engines" and it says something about degrees and torqing. Does anybody know just the torque specs on the "1-2-3" without having to use the degrees method??? btw i'm using aluminum heads thanks
so 70 lbs. for the final pass and this is for alum. Heads? IS that with any oil or anything on the bolts?
I thought I heard ARP recommeneds 65 with their moly and 80 with just 5 w 30 oil??
ok i'm thinking anything in between 65# and 70# for the final pass is good. on the first pass 22#-50#. if nab runs 10's on a stock block thats good enough info for me
Btw thanks for that info..on the head bolts, wd. ARP bolts be the same can I just use the 50 and then the 70 dry with no moly and with thread sealer will that change the specs at all??
77 is the real number and that's with the teflon tread sealer on one end and oil at the top. Actually 80 is not too much and is a good round number to torque to. The steps are 50, 60, 70, 77 then 77(or 80). Start with the center bolt and work in a circle. Do this correctly and you won't blow more head gaskets then years then you've been alive.
Thanks Mike,
So with using these alum . Heads and ARP head bolts I wd. put thread sealer on the bolts and what say 5 w 30 oil as well and torque all as you say? Does it matter using the ARP bolts as they say something they require diff. specs when using their bolts??? ( 65 lbs with their moly and 80 when using just 5 w 30 oil )
Also do I need to use loctie as well so they won`t back out , I don`t think so but might as well ask that as well?
Thanks Chris
I tried that bullsh*t they talk about and pushed a gasket on the fourth dyno pull. Teflon sealer on the threads and oil at the top, 77 to 80 ft lbs, no lock-tite any where and you're good to go.
Discussion Starter · #9 ·
Thanks Mike,
I appreciate that info from ya...
Chris
oh and that thread sealer is just the same stuff plumbers use for pipe threads white in color that comes in a tube, or should I buy the stuff GM wants 20.00 a tube for ??
1 - 9 of 9 Posts
